Re: cub 154 solenoid clicks won't turn over
Posted by Buzzman72 on July 29, 2011 at 13:14:37 from (74.129.195.67):
In Reply to: Re: cub 154 solenoid clicks won't turn over posted by JRSutton on July 29, 2011 at 11:02:56:
1. Check battery voltage.
2. Check battery cable terminals [BOTH ends]. If solenoid is remote from the starter, also check cable from solenoid to starter.
3. Check your ground, for both the battery AND for the solenoid.
4. Make sure engine isn't mechanically or hydraulically locked up, by attempting to turn engine over by hand.
5. THEN check starter and solenoid.
