Re: Super M hydraulic return line
Posted by Armand Tatro on July 29, 2011 at 20:22:11 from (98.227.26.140):
In Reply to: Super M hydraulic return line posted by Fixerupper on July 29, 2011 at 10:19:37:
Before the return line returns to the hyd. tank you could make a simple oil cooler with pipe nipples and fittings and set in front of the radiator. Use as much steel line as you can instead of hoses because steel gets rid of heat faster than hoses and the cooler will maby add an extre gal. of oil capacity. Use kind of zig-zad pattern in front of the radiator. Any questions? Armand
