Re: Low Ash oil for a Cub
Posted by justin on August 12, 2000 at 22:06:13 from (216.161.98.146):
In Reply to: Low Ash oil for a Cub posted by Bill Oakes on August 12, 2000 at 20:49:22:
You can use any type of oil you like, as long as you use the recomended weight I assume the cub uses SAE30 just like the rest of the farmalls of the time.. The Case IH oil is the factory recomended oil for your tractor.. The IH #1 engine oil has been around a long time, and is regarded as probably the best around.. I feel that it is always best to use the fluids designed for the tractor, but many will tell you otherwise..
Post A Followup
: Re: Re: Low Ash oil for a Cub
