Re: Super M runs wide open????
Posted by Janicholson on July 30, 2011 at 06:39:30 from (67.72.98.45):
In Reply to: Super M runs wide open???? posted by JC69 on July 30, 2011 at 06:28:23:
As Delta Red Indicates, the attachment point of the carb to governor tube is most likely the issue. The cap on the far end of that tube where it turns down into the governor, and the governor plate can be removed to look at internal parts for binding or broken components, but they usually fail such that the tractor will not go above idle, or will not get to rated RPM. Jim
