Re: Carter UT
Posted by karl f on July 30, 2011 at 21:40:16 from (172.162.50.203):
In Reply to: Carter UT posted by Livin the Dream on July 30, 2011 at 04:06:28:
The only mixture screw on that carb is your
idle mixture. It has a fixed main jet orifice
instead of an adjustable jet.
3 turns is usually for a main jet, but only as a
starting point.
Idle screws are typically between 1 and 2 turns
as a starting point and your final adjustment
could be 1/2 or 3 turns.
Like the other poster said, there is also a screw
for your idle speed near the throttle shaft.
remember, carb adjustments vary greatly from
the initial number of turns mentioned in the
book for installation.
good luck
karl f
