Re: Can you help my older neighbor figure out what model ...
Posted by gene bender on July 31, 2011 at 02:57:55 from (207.177.56.53):
In Reply to: Can you help my older neighbor figure out what model Farmall posted by Cheryl Pritchett on July 30, 2011 at 17:19:39:
You also cant be sure the seat bracket is original with the tractor. What is the serial # on the block beneath the #1 spark plug. Your tractor doesent have to have hy just because its a SA according to your # posted.
