Re: farmal m turns over super slow
Posted by pete_5959 on July 31, 2011 at 03:23:39 from (138.162.128.55):
In Reply to: farmal m turns over super slow posted by ronba on July 31, 2011 at 00:20:58:
What is the voltage at the starter when you are trying to turn over. I assume you are still using a 6V system and no one has messed with the timing. Voltage should be darn near 6V. I use double ott welding cable to make my battery cables with correct sized solder on type terminals. The 6V battery will spin the motor even in cold temps.
