Posted by farmallboy15 on July 31, 2011 at 07:36:50 from (67.54.192.52):
ok i figured out what was causing the fuse to blow, there was a open wire inside one of the lights. but i still cannot figure out why the generator is not charging.the gen is good. i have spark when i jump the hot terminal to the ground. i also have all connections on gen cleaned up. it has a cut out relay and 4 position switch, all wired correctly. i have light box to steering post to rearend connections clean. i was able to follow all of john t's diagram to the grounding the light switch, what part needs grounded? is there something im missing?with good gen, good switch, good ammeter, good wiring, good battery im still not getting a charge... thanks
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
