Re: farmal m turns over super slow
Posted by Tom Fleming on July 31, 2011 at 08:11:32 from (67.20.249.95):
In Reply to: farmal m turns over super slow posted by ronba on July 31, 2011 at 00:20:58:
In addition to what others have already suggested, there is another issue that I just fixed for someone. They had their starter rebuilt. Put it on the tractor and it barely turned it over. I made them up new cables, soldered conntections, the whole works. Same result. I even made up a temp cable for ground and ran it from the positive post on the battery to the mounting bolt on the starter. Same result. Checked out the new switch on top of the starter, all good.
So, I opened up the starter, and low and behold, the brushes had NO SPRINGS. Uh, DUH to the place that rebuilt it. I corrected the issue, and told the person to go back to the place he had it rebuilt and slap the guy.
What I am trying to say is that you may also want to check that the brushes are making good contact on the armature.
