Re: Farmall B-Need more power
Posted by old on July 31, 2011 at 13:34:20 from (209.86.226.59):
In Reply to: Farmall B-Need more power posted by Jason In IL on July 31, 2011 at 11:38:49:
If your going to rebuild it there are a number of small things you can do to bring up the HP but you also may not really need it since you could well just have a tired engine. You can do the over bore sleeves, mill the head a little bit, add a stronger spring to the gov. and maybe re-jet the carb. That said my little BA, which is half B and half A has a B engine A trans/rear end. Has enough power to run a 6 or 7 foot sickle mower in real thick hay
