Re: Low Ash oil for a Cub
Posted by Burrhead on August 13, 2000 at 09:25:22 from (12.74.17.24):
In Reply to: Low Ash oil for a Cub posted by Bill Oakes on August 12, 2000 at 20:49:22:
If that tractor has'nt ever been up graded to detergent oil you want to stay with some sort of non-detergent oil for it.
If you start using modern detergent type Pennsoil, Quaker State or simular oils the detergents will break the crud loose in the engine that has built up through the years and will grind down the bearings and rings.
Post A Followup
: Re: Re: Low Ash oil for a Cub
