Re: farmall m radiator petcock
Posted by 55 50 Ron on August 01, 2011 at 07:48:54 from (206.8.2.87):
In Reply to: Re: farmall m radiator petcock posted by JRSutton on August 01, 2011 at 05:32:58:
There IS a drain at the bottom of the radiator. If you drain the block you are only getting part of the coolant out. The radiator drain is usually a pipe with a cap on the end. Looks like plumbing pipe. It's located on the right side (as you sit in the tractor seat) of the lower radiator tank.
