Re: back firing upon start up.
Posted by old on August 01, 2011 at 09:13:05 from (209.86.226.40):
In Reply to: Re: back firing upon start up. posted by Scotmick on August 01, 2011 at 09:08:20:
In line gas filter??????? Those most of the time cause more problem then they are worth. I throw them away on all tractors since the sediment bowl if it has the correct parts in it work better then the in line filters ever will. Plus in line filters most of them that is are made for systems with fuel pumps and most tractors do not have fuel pumps and the 240 I know does not. And yes running lean can cause one to back fire as can valve set to tight and over times valve do in fact slowly get tighter from wear
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
