If it backfires out the carb, that's generally due to too much advance in your timing.
If it back fires out the exhaust(or both exhaust and carb) it's generally either too rich or too lean.
What causes the backfire in that case is that the gas/air doesn't fully burn in a cylinder, gets exhausted out and then burns while in the exhaust manifold.
Smelling gas probably means it's too rich, but not a guarantee. Since you're dealing with innefficient burning, it could be too lean and you're smelling what didn't burn because of that.
A better indication is black smoke, is there any?
Follow other's advice on adjusting the carb, but first make sure your choke is opening properly.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
