Re: Farmall 200 starts then dies
Posted by old on August 01, 2011 at 12:24:40 from (209.86.226.54):
In Reply to: Farmall 200 starts then dies posted by Alex829 on August 01, 2011 at 11:56:04:
Do a little trouble shooting. #1 check for a blue/white spark that will jump a 1/4 inch gap. #2 pull the drain plug from the bottom of the carb and let the fuel flow for say 5 minutes or so. Catch that liquid gold so you can look for water/dirt/rust in it and also reuse it. You need 3 things to make an engine run. Spark/fuel/compression all at the correct time so you are loosing one of those and not likely to be compression
