Re: H engine Locked Up
Posted by pete 23 on August 01, 2011 at 17:23:52 from (74.32.234.149):
In Reply to: H engine Locked Up posted by B crick on August 01, 2011 at 17:13:11:
Take the starter off and use a bar on the flywheel ring gear. You can feel what is going on that way and not damage anything. Then if you can move it a trifle, put some oil of most any kind in the cylinders. You may have stuck valves along with stuck pistons and if you did pull it and it turns over , well, bang goes the valves, rockers and push rods or maybe head. Every one has their own secret loosening oil mixtures. They all work about the same.
