Posted by glennster on August 01, 2011 at 17:27:33 from (99.90.9.153):
In Reply to: H engine Locked Up posted by B crick on August 01, 2011 at 17:13:11:
pull the spark plugs and squirt either automatic transmission fluid in there, or your favorite penetrating oil, pb blaster -kroil-ect, but not wd-40. let it soak for a few days, then put the tractor in 5th gear and rock the back tires back and forth. i have also set the rear tires on a short ramp and left it parked in 5th gear. when it breaks loose, the tractor will roll slowly down the ramp. i would not try and pull start a stuck motor. keep adding penetrant to the cylinders till she breaks loose
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
