Re: 460d hard to start when hot
Posted by pete 23 on August 01, 2011 at 17:34:56 from (74.32.234.149):
In Reply to: 460d hard to start when hot posted by milo7890 on August 01, 2011 at 14:11:54:
You might be lucky, some times the delivery valve stop screw comes loose and you have that exact symptom. If you intend to take pump off for repair anyway, you could pull the transfer pump off the end and there is an allen headed screw in end of rotor. Just check to see if it is loose. It does happen. Torque it to about 90 inch pounds of torque. If it isn't loose you have lost nothing except a few minutes of time.
