Re: H engine Locked Up
Posted by rustred on August 01, 2011 at 19:16:33 from (74.200.18.156):
In Reply to: H engine Locked Up posted by B crick on August 01, 2011 at 17:13:11:
definitly dont pull it. i have seen the sleeves broke off the top and pulled down. i do the same thing as jrsutton posted. that little tiny engine is only a 1/2 day project to get cleaned up properly. i dont believe in scraping the rings up and down in rust. even at the same time can remove valves from head and clean out rusty guides. with that rust in there just going to increase wear on parts faster.cant see myself waiting on a magic potion that i have never have luck with.the time to put oil in cyls. is when tractor is to be parked for extended time and keep exhuast covered all the time when tractor is not in use thus preventing stuck engines.
