Re: Farmall 130 - HELP, NO SPARK AT COIL - janicholson or ot
Posted by rustred on August 01, 2011 at 22:08:07 from (74.200.18.156):
In Reply to: Re: Farmall 130 - HELP, NO SPARK AT COIL - janicholson or ot posted by RTR on August 01, 2011 at 19:45:38:
squirting some oil in those dry cyl's will benefit you more than that crazy ether. gotta get that compression up. make sure the timing is on also. pull starting it is better than that ether also, at least the oil is being splashed on the cyl's and not being washed off with ether.
