Re: H engine Locked Up
Posted by JRSutton on August 02, 2011 at 05:57:30 from (75.130.109.233):
In Reply to: Re: H engine Locked Up posted by B crick on August 02, 2011 at 05:43:35:
Sounds reasonable. If it's only going to get some light occassional use, and you don't have any experience with pulling a cylinder head anyway, then your plan sounds like the best (if not only!) course of action.
It'll most likely work out just fine following some of the suggestions here.
Good luck with it.
Let us know how it goes.
