Re: H engine Locked Up
Posted by El Toro on August 02, 2011 at 06:05:37 from (108.15.86.54):
In Reply to: Re: H engine Locked Up posted by B crick on August 02, 2011 at 05:43:35:
Once you get the engine free and have finished using it for a long period of time remove the sparkplugs and squirt engine oil on top of the pistons then crank the engine over a few times.
Then squirt some more oil into the cylinders. I would keep it sheltered too from the weather. Hal
