Re: H engine Locked Up
Posted by Paul Shuler on August 02, 2011 at 08:19:46 from (170.29.248.3):
In Reply to: H engine Locked Up posted by B crick on August 01, 2011 at 17:13:11:
Just a thought, you might pull the starter off to make sure thats not what is stuck. Mine did that in June. Just started to loosen a bolt on the starter then there was a pop and everything was loose.
