Re: Super M Hydrolic pressure
Posted by john d on August 13, 2000 at 15:05:11 from (206.141.74.34):
In Reply to: Super M Hydrolic pressure posted by jim on August 12, 2000 at 22:04:27:
The two ports on the left side and the one port on the right side of your tractor are ALL pressure ports. Oil returns to the pump reservoir through the SAME line it came out. That's why the system is called "single-acting" and relies on gravity to lower your 3pt hitch. The left-front port and the right-side port are on the same circuit. The left rear port is a "delayed" port that doesn't respond until pressure reaches near maximum in the front two. It was designed to lift the rear gang of cultivators after the front gangs had raised. It's timed pretty well for 3rd or 4th gear, depending on tire size and cylinder size. When both circuits are in use, pushing the control rod past the first detent spot releases pressure on both front ports. Pushing the control rod all the way down releases pressure on the back port. Auxiliary valves may be added to allow the system to act as a double-acting system. These provide a return line to the fill port on top of the unit. The fill port may also be used as a return port when driving a hydraulic motor. Red is right-on concerning the pressure, assuming no one has "fiddled with" the pressure relief spring!
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
