Re: Super M hydraulic return line
Posted by M Diesel on August 02, 2011 at 17:54:25 from (12.24.61.12):
In Reply to: Super M hydraulic return line posted by Bob M on July 29, 2011 at 10:32:48:
Basically 10 GPM at nominal load of 400 PSI, derating to 8 at 800 PSI. Not the tightest pump, but they do last.
As said returning at the bottom is nicer, the filler neck return is prone to foam problems.
