Re: cleaning out an H transmission/rear end
Posted by CNKS on August 02, 2011 at 18:10:45 from (216.144.104.128):
In Reply to: Re: cleaning out an H transmission/rear end posted by Jason the Red on August 02, 2011 at 05:48:29:
NO, the operators manual says to change the fluid once a year or 1000 hours, whichever is first. However, it says to dilute with 2 gal keorsene if the temperature is below 32 degrees F. You let it get warm, then drain to the level plug. Then you drain the diluted stuff and replace with 90W when the temp is above 32. I doubt if many people did the kerosene thing in variable weather.
