First take a look a the V in 6-29-V. That is a date casting code indicating June 29 of some year. V was not used. Both U and W were used for 1951 which, without checking out the other ****DX numbers for being right to this suggestion, would indicate you might have a Super A instead of and A. Look over the rest of your tractor (torque tube, tranny, final drives), as well, for castings in similar format to see if the match up or might more clear to read.
The motor serial number that I believe Old is referring to is found on the front right side of the motor. It is stamped into a milled flat spot, at the upper edge of the crankcase. Below the head gasket and generally underneath the #1 plug. It may be obscured under a lot of crud and by the speed control rod to the governor, but it's there. That will tell you at least what year the motor is. If it's not near either end of the range for the year, it will generally tell you the year of the tractor. The numbers got apart between chassis and motor after production started at Louisville. A reliable indicator, as long as any other date casting codes are within a few months of the casting date on the motor.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
