Re: Identify year model of Farmall A
Posted by gene bender on August 03, 2011 at 04:53:33 from (207.177.56.53):
In Reply to: Identify year model of Farmall A posted by ROSS123 on August 02, 2011 at 21:47:09:
It sounds like your tractor has been pieced together with parts from other stuff. First the grille thats from a power unit. You need the cast codes from other parts on the tractor. THE 6*29*V is one een though the "V" was not used. Look on the tranny by the clutch pedal there should be one there. The # on the block under neath the #1 plug will be a FABXXXX that # could or could not be the original engine. Magnetoes were the standard ignition used on the Bs
