Re: Hydraulic pump question / 400 Farmall
Posted by pete 23 on August 03, 2011 at 06:49:49 from (74.32.234.149):
In Reply to: Hydraulic pump question / 400 Farmall posted by biggerred on August 02, 2011 at 19:35:28:
You can pull seal out, either collapse it or drill holes and pull with slide hammer seal puller. Note the crimp around edges, I always work that material out so as to not damage new seal. If shaft has a groove seal won't hold. I also locktite them in rather than crimp or stake. That little key in the drive may give you some crap going back in place.
