Re: 806 stopped moving and no power steering
Posted by The tractor vet on August 03, 2011 at 08:18:21 from (75.19.127.83):
In Reply to: 806 stopped moving and no power steering posted by Brandon Anderson on August 03, 2011 at 07:00:44:
well if ya got pto and hitch and remote hyd. then i would be checking pressure on the MCV , as you say no steering and no go . Does your tel tale oil lite work??? as if it is on then you have no pressure on the MCV . This like also tells ya if the engine has oil pressure so if it is not working then fix it. Now it could also be the main clutch but you would have steering . If you had no hyd. at all and the PTO was not working then it would be the PTO input and hub on the pressure plate .
