Re: carb drips
Posted by ltf in nc on August 13, 2000 at 19:02:04 from (206.228.214.115):
In Reply to: carb drips posted by Jack Gibson on August 13, 2000 at 06:25:38:
There is a vent hole but you need to leave it open. You are still having problems with the needle/seat and the float height. You have trash under the nedle or the float is incorrectly set. Short of a line or fitting leaking at the carb, this is all that will cause the problem. Most people just cut the fuel off at the tank when not using the tractor. If you really want to go to the effort to correct the problem, repost and I will try to work with you through the problem.
Post A Followup
: Re: Re: carb drips
