Re: m govenor
Posted by pete 23 on August 03, 2011 at 10:05:34 from (74.32.234.149):
In Reply to: m govenor posted by ISteve on August 02, 2011 at 17:14:19:
The two main important parts in that governor are the weights and pins and thrust bearing. I can't fix a thrust bearing if it is loose or rough but have fixed many weights and pins. I drill them out to a size that a roll pin will fit tight in the carrier and free in the weights. If holes are worn very egg shaped you have to drill very careful to try to keep hole centered. Last governor I put a kit in cost over 400 dollars and that was over twenty years ago.
