Posted by Janicholson on August 03, 2011 at 10:10:38 from (67.72.98.45):
In Reply to: Re: Farmall M Wiring posted by Alex-41jdb on August 02, 2011 at 20:44:11:
It is a one wire alternator. There is no provision for a push button "excite" If it is not charging, Tested at the battery with it running near full throttle, I suspect the alternator is at fault. The one wire systems found in auto stores are aftermarket remade 10si or similar Delco alternators with a patch inside that allows them to sense the voltage on the big post all the time. If they are of best design, they draw just a few Milliamps all the time, running or not. If not, they can draw more and run the battery dead in a week to a month. If mine, I would rewire it myself using a 3 wire Hitachi alternator (L terminal is equal to a Delco #1 terminal, S equals the Delco #2 terminal). Wire it as bob"s diagram, and use small nylon wire ties to group the loom. Use #10 wire for the alt output to the amp gauge load side, and from the amp gauge to the starter switch. 00 gauge for bat cables, and 12 gauge for everything else. Use original color code, or make your own, but draw it up in a neat way to refer to and give to it"s eventual owner at some future day. Use shrink tubing and solder on terminals for each connection. When it is correct, then tape it, or put loom tubing on it. I suspect the push button was used for either a starting relay (like later 400"s), or an exciter not used now, Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
