Re: 806 stopped moving and no power steering
Posted by Janicholson on August 03, 2011 at 10:21:32 from (67.72.98.45):
In Reply to: 806 stopped moving and no power steering posted by Brandon Anderson on August 03, 2011 at 07:00:44:
A common "cure" that is not too expensive is to over fill the Hydraulic system with 5 gallons or so. It harms nothing, and covers a leak in the MCV pump intake system that could be your problem. The vet is correct, Proper eventual fix would be to take it apart and repair the intake. There are many tractors being used daily with extra fluid as the fix. If this does not make it operate, pressure diagnosis of the MCV is next. Jim
