Re: Identify year model of Farmall A
Posted by Jim Becker on August 03, 2011 at 21:22:36 from (173.57.144.251):
In Reply to: Identify year model of Farmall A posted by mkirsch on August 02, 2011 at 21:47:09:
That is what I think too. Check other major castings for an "N" date code. If most match up, it is probably a '44 with an earlier PTO. If the date codes are all over the place, it is as Gene commented. In either case, the engine was from a tractor with the matching serial numbr.
