Posted by gene bender on August 04, 2011 at 04:39:47 from (207.177.56.53):
In Reply to: 504 stops running posted by cjmal on August 03, 2011 at 16:06:34:
Quick as soon as it stops take the drain plug out of the carb to see gas flow. You need to find out if its gas or spark. If it runs for 5min sound more like spark although it could be the gas tank vent is not doing its job. Just for a quick fix loosen up the gas cap mite want to tape it so it doesent fall off but see if the engine stops after 5min again and that would tell you quick the cap vent is not working. You dont need to change parts do some quick easy things first. Yours wouldnt be the first one to have a bad gas cap.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
