Re: Farmall 140 Possible Oil Leak
Posted by SouthernFarmall on August 04, 2011 at 07:46:25 from (71.53.116.135):
In Reply to: Re: Farmall 140 Possible Oil Leak posted by Hendrik on August 04, 2011 at 00:07:40:
I keep an eye on the engine oil, and it is not overfull. However, the hydraulic reservoir does leak at the bottom of the reservoir, and the fluid drips off the clutch hand hole cover. That is the only hydraulic leak I know of.
SF
