Re: Super A clutch finger adjustment
Posted by gene bender on August 04, 2011 at 09:33:47 from (207.177.56.53):
In Reply to: Super A clutch finger adjustment posted by David Lampman on August 03, 2011 at 13:21:57:
The new one is set just install an it will be ok i have installed many and they are set when you get them. They should all be the same height after you get it mounted to the flywheel.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
