Re: Steering Question
Posted by pete 23 on August 04, 2011 at 13:41:12 from (74.32.234.149):
In Reply to: Steering Question posted by farmall706 on August 03, 2011 at 21:02:00:
If you really wind on it you may well be able to suck up some oil and turn the wheels. If someone has replaced the sump check valve with a plug as some do when doing ta replacement jobs then you will not be able to . The oil does leak down when shut off and in a couple different places so it is pretty normal to have a no steer situation when engine is shut down for a bit.
