Weird hydraulic issue with IH 464
Posted by Paul Stout on August 04, 2011 at 14:04:05 from (4.244.84.41):
I am working on a 464 that has set up for several years. When you start the tractor, the hydraulics work well. After it runs a minute or two the lift and power steering barely work. You kill the tractor, restart it, and they work again a few minutes. It doesn"t matter if the tractor has been run and hour or a minute, it acts the same. The fluid looks and smells clean. Is this a pump or MCV issue or?? Thanks for the insight.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
