Re: Does anybody use the primer cups?
Posted by oldiron29 on August 04, 2011 at 15:44:50 from (74.88.11.200):
In Reply to: Does anybody use the primer cups? posted by Super H Mike on August 04, 2011 at 14:40:12:
Mike, The cup's were used if you had a kerocene tractor and you stalled or had shut the tractor down when on kerocene. You would put some gas into cup's to get the tractor started. I have used them on first start up's to prime the cylinders. It is easyer than pulling out 4 plugs and squirting gas in. oldiron29
