Re: 3PL
Posted by Redfan on August 14, 2000 at 05:23:49 from (203.87.53.9):
In Reply to: 3PL posted by Rob Johnson on August 14, 2000 at 02:17:36:
Evening Rob, are you getting wet down there in Vic. Converting the existing 3pl to double acting would be a bit difficult, and an option I've seen used a lot is to rig up one or two external rams, and couple them to the lift arms of your linkage. It would only work of course if you have double acting hydraulics, or are able to convert yours to double acting. If you need more info. E-mail me. Gus.
Post A Followup
: Re: Re: 3PL
