Re: Does anybody use the primer cups?
Posted by Farmallb on August 04, 2011 at 18:37:28 from (67.142.178.26):
In Reply to: Does anybody use the primer cups? posted by Super H Mike on August 04, 2011 at 14:40:12:
One winter in 68/69 early in the morning neighbor came up. It was wintertime on a Sat morning round 7 00. Wanted to know if I could pull him out. There was around a foot of snow on the ground, and it had got down round one side or the other of 20 below. I finished breakfast and went out and tried to start her up like always. No go. I put some gas in the primer cups, and she did start. I had 2 log chains. I wrapped them 1 each around each rear tire and went out. Got in front of him. He didnt have a log chain. I took one off and he hooked it to his car, and I hooked the other side as near to the left wheel as he had ran of the L side. I took up the slack by trying to cut across and when tight I hit the R brake in bits and with him trying we got it out. Put the chain back on the R wheel and came on home. It was a F-20 with foot brakes.
