A hot coil is a bad coil. They can be hot from engine heat and running behind the radiator, but they should never be hotter than the housing of the distributor where it mounts. The polarity of the coil matches the polarity of the battery. If negative ground, the coil negative is hooked to the distributor. Hooking it wrong will not hurt it or cause heat, it might not run as well for a variety of spark at the plug reasons, but no damage. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
