Re: Farmall 560 needs clutch??
Posted by Janicholson on August 04, 2011 at 20:34:31 from (67.72.98.45):
In Reply to: Farmall 560 needs clutch?? posted by C Bergan on August 04, 2011 at 20:20:52:
First check the pedal freeplay. Push on the pedal with your hand. It should move pretty easy for an inch and an eighth before getting hard to push down if it is easy at first, and the TA is working correctly and adjusted correctly) is slipping. If it is hard to push down immediately, (no slack) they mis-adjusted it and need to correct their mistake. (it is possible to improperly adjust a clutch to make an owner think it needs a new one, instant repair job) Give them a chance to make it right if it is improperly adjusted. It takes a good experienced mechanic, or owner, to adjust the clutch TA correctly, especially on a machine with worn pins and clevises in the TA linkage. Search TA adjustment in the archives, Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
