Re: Farmall Restoration
Posted by Tom Fleming on August 05, 2011 at 02:12:14 from (67.20.249.95):
In Reply to: Farmall Restoration posted by burowa4 on August 03, 2011 at 19:31:22:
Tools = $$$$, and if you don't have all the tools/knowledge, then that = $$$ also.
I have been rebuilding and restoring antique engines ( not just tractors) for over 35 plus years now, and have worked on mechanical things even longer. I am still buying tools so I can do things. Growler, armature lathe, valve grinders, seat grinders, hydraulic press, sleave puller, hones, ridge reamers, taps/dies through 2", the list goes on for ever. About the only thing I don't/can't do now is turn cranks or grind cams.....and I have my eye on tool auisition.
I encourage you to spend time on this board. Gene, Jim, and others have a wealth of experience and knowledge. So, anything we can help with, just ask. However, remember one thing: If something is worth doing, it is worth doing it right. Do the best your pocketbook and time can stand. It is better to be a bit patient and get it right that it is to cobble something or shortcut that ends up costing more later.
Good for you that you are interested in getting into this, and anything I can do to help or share, I am very happy to do.
