Re: Farmall Restoration
Posted by JRSutton on August 05, 2011 at 07:24:28 from (75.130.109.233):
In Reply to: Farmall Restoration posted by burowa4 on August 03, 2011 at 19:31:22:
Very personal decision, and depends on what your needs are - but I'd recommend going with a smaller tractor for your first one. A/Super A
They're a LOT more fogiving in weight.
They're easier to transport safely. Easier to lift safely. Easier to remove and manuever parts safely.
For example, a rear wheel from an A falling on you would hurt you, but a calcium filled wheel from an M would squash you like a bug. The same could be said of many of the various parts you may need to get into.
Of course, it depends on what your ultimate use is for the tractor.
But even so, if you're totally new to it I say go small to learn, then sell it and try something larger. The knowledge you gain will transfer nicely to the larger machines. If you're carefull you can keep your costs somewhat contained, and hopefully not lose your shirt in the process.
Whatever you do, good luck. The more people keeping these old machines alive, the better.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
