thanks jim, H MN, and The Red
Posted by Cityboy in Minneapolis on August 14, 2000 at 06:11:37 from (207.108.84.20):
My co-worker says thanks. This is what the shifting problem was on his M. After removing the shifter, he noticed that the 1rst/reverse shift fork was slid back some. He moved it forward with a long screw driver, reassembled, and it worked. If it continues to happen it certainly sounds like the shifter has worn a little short.
Post A Followup
: Re: thanks jim, H MN, and The Red
