Re: 49 farmall M
Posted by janicholson on August 05, 2011 at 12:52:19 from (199.17.6.10):
In Reply to: 49 farmall M posted by ArloInt on August 05, 2011 at 12:25:21:
All is well with the voltage readings if the points are open!
Check the voltage at the side of the distributor when the cap is off, and you are opening and closing the points. This should also make spark!, be careful!
If it does not, check the pass through for opens or grounds to the housing. Plastic insulators must be in place. Jim
