This is stricly a guess. The temp sensor is in the top left rear of the block if I remember right. Sounds like you have something, what I have no idea, that allows the coolant to drain away from the sensor when going downhill. There is no load on the engine at that time, the temp should go down. Otherwise maybe the sensor has so much crud on it that it won't read right. You might take it out and look at it, provided you can remove it without breaking it. Your "level" temp is common for those engines. The edge of the red is the boiling point for the pressurized system, which I would guess to be 220 or so. I forget how much 7 or so lbs raises the boiling point. Antifreeze raises it too.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
